For your consideration, here is a SoundOff Signal ETL5000 48" roof lightbar, complete with breakout box and wiring to connect the breakout box to a switchbox. Mounting straps (not pictured) with a black finish are also included, but they're very short and barely extend past the feet.
The corners and front warnings are red/blue, it has dual-color modules to the rear, red/amber & blue/amber. The white takedowns and alleys are LED.
It's in good condition. The lenses have no noticeable yellowing and the only cosmetic damage worthy of note are some scratches/scuffs on the top cover on the passenger side. It needs a new grommet where the power/signal wires exit the bar. The power and signal wires are on the short side. Since the signal wire is a standard network cable, if needed & requested, I'll make a new one in the length the buyer needs to install the bar.
For warning patterns, each symmetrical pair of lightheads is controlled independently, both pattern and activation.
For the demonstration video, I just activated all the warning patterns, plus the alternating amber/warning color pattern on the rear. There are plenty of other activation options and patterns for this bar.
Shipping will be at no additional charge for the lower 48 states in the USA via UPS ground.
