theroofable
I recently removed a carson 100 watt compact speaker, which I do not believe has any drain holes. The output was greatly reduced, and thought it was time for an upgrade. When I removed it, water poured out of it, Im assuming because it was tilted slightly upward (due to the design of the grille, only way possible). I replaced it with a dynamax MS100, older cast style, that I painted black. Much better, but it is still angled slightly upward, but this one has drain holes, so it should be ok correct? I dont want it to be ruined in a few years. Anyone have input on this? I assume that it will get water in it anyway its mounted, but when angled downward slightly it should run out easier. I usually do it this way, but it wouldnt fit. FYI, used with an omega 90 airhorn, sees little use.
On a side note, I cleaned up the carson speaker, took it apart and dried it out. Now im going to test it and see if it will come back or if its garbage. They only have a 1 year warranty on them
Thanks guys.
Thanks guys.
