pyro29
I'm looking to have separate control over individual colors on a split color Vertex. Obviously the factory cable from the open end to the driver is the standard four (4) wire cable.
Does anyone have any experience with gaining separate control over the two different colors in these units? My guess is that there will be a four (4) wire cable between the driver and the lamp head which would allow one color to be taken off the driver and powered through a different means, but, again, this is only a guess. Assuming I am correct, does anyone know of any problems or issues in removing one color control from the driver? What voltage does this head want to see, if run without a driver? I did try one with a different manufacturers flasher module and it seemed that a full 12 volts was a little too much.
Thank you for your assistance.
