Split ion
Steveo17
29
Essex uk
Good evening I am hoping some one may be able to help me out. I have just got a pair of blue / white split ion light heads the independent ones but have no instructions with them. On the back there are 4 wires a blue one for power to the 3 blue led then a plain white one for power to the 3 white led then black for earth and a grey sync wire. Is it possible to change the flash pattern on these or is it a set pattern. Cheers steve
Da-Sarge
393
Canada
If its a smart head then there should be a white with violet line on it thats the patturn select wire it should allow you to set the patturn to what ever your choice is the color of choice does need to be powered on to change its patturn if its a used head the patturn select wire might be cut off
bfpd108
