Spotlight wont work.. HELP
fireman616wfd
2,126
Oxford, MS
We had a unity spotlight go out on a 2007 CVPI last week.. the officer and 2 or 3 others have messed with it but cant get it to work. He has tried replacing the buld, then the rear switch, now someone has put a test light to it and says there is no power going to the switch. *NOTE* the reason the switched was replaced is because his other one broke, this is when the spotlight "quit working".
I havent messed with it because i dont have a clue and he said to get on here and ask for any suggestions. My suggestion was a fuse maybe but now its to what fuse and which fuse panel is that thing hooked to? he pulled out and checked many fusses and said he didnt see one blown..
Any help or suggestions would be greatly appreciated because this car is a slick top and its the only lighting he has.
unlisted
May 20, 2010
7,331
NA
Gotta play "find that fuse!" If that is okay, double check to make sure there is power going TO the FUSE.
Still not working/fuse/power to fuse okay? Trace the wire from the spotlight TO the fuse. Most likely a break somewhere. I've heard of the power wire sometimes getting so twisted up/turned/spun around (or installed improperly) that it literally breaks the power lead.
Failing all that, just remove the (original) fuse, and run a new fused line to the spotlight.
unlisted
May 20, 2010
7,331
NA
Well that would be the first problem than... Get searching, and also a label maker.
Want to know the "OMGWTFBBQ" wiring mess trick? Turn everything on, and start pulling a fuse one by one- and label each one when something turns off.. ;)
Fast LT1
2,017
Sedgwick County, KS
+1 Thats the best thing to do, and it ticks me off when people don't label their wires or include a diagram.
EVModules
864
Deer Park, WA
Oh boy, if you were in my shop, I would have turned it around and sent it on your way in 15 minutes. I'd have taken off the switch cap and test for power. If present, replace cap and remove the bulb & test the power tip & ground.
Sometimes, the spotlight would pull away from the handle and break electrical contact. To check, remove the handle with a 3/8 nutdriver (don't remove the bolt completely, loosen it almost all the way and hit it towards the shaft to loosen the nut on the opposite side) The inner shaft should be approx 1" longer than the outer shaft. You may need to loosen the bolt that tensions the inner shaft and push it towards the center of the vehicle. Tighten carefully until it moves freely and holds position when you let go.
sephora99
66
Connecticut, USA
It might be worth noting (though it should be common knowledge) that the spotlights use their structure and being bolted to the vehicle frame as their ground connection. Because there is a separate piece inside the mounting tube that is connected to the car frame, it may be worth checking to make sure that is getting connection too. Also there are electric brushes in the spotlight head end which carry the current to the bulb, sometimes those can get gunked up with grease from the rotating gears. Beyond that, if there really isn't power coming into the wire then it sounds like a vehicle specific problem.
EVModules
864
Deer Park, WA
As easy as it is to ask that question. It's only constrained by any stuck hardware & Ability to follow the adjustment procedures as not every fastener is designed to be tightened.
fireman616wfd
2,126
Oxford, MS
ok i was wondering because now we have a car that only the head of the spotlight will spin.. the shaft wont move and the light wont lay down, have to leave it standing straight up. :roll:
EVModules
864
Deer Park, WA
Try loosening the bolt on the shaft, next to the head. It's not supposed to be tight, only partial to keep tension on the shaft, enough to hold it in place but allow the operator to move it.
sephora99
66
Connecticut, USA
Assuming this is a typical Unity spotlight, there is also a bolt/screw on the handle side which could cause the shaft to bind up if it is too tight. EVModules' suggestion of the bolt on the outside near the head is also valid. It would be the biggest one going sideways through a friction bracket. It is not uncommon for these things to bind up if they are not properly sealed/adjusted and lubricated. I had to completely dismantle mine (head and everything), use some break-away and re-grease all the moving parts. In fact mine has been getting tougher to rotate recently in the same fashion as yours. Time to lube it up again.
JBM533
