EVModules said:Are you using the correct phone cord? To check, butt the ends towards each other. The colors should match up across from each other.
If so, what is the keypad showing? If nothing, either you have a bad amp or a pico fuse that's blown. It's on the bottom board, near the front. Looks like a resistor but usually all green.
gman021 said:Thanks for this pics, that will help me when I take this bad larry apart. Does anyone know of a good place to get pico fuses? I tried googling it, but nothing reliable.
gman021 said:I'll go to radioshack now and see if the have a 4 wire cable that the colors match up. If you have some pico fuses on you, I'll send it to you. Can you get a 4 wire cable?
EVModules said:PM Sent.
gman021 said:Haha ya I've dealt with Sean before.
But no one came right out and said that fed sig cables are completely different, and therefore there was 0% chance they would work.
