Strobe Edge corner module part number
Ben E.
Iowa, USA
We have a customer that is 45 minutes away that has a corner strobe module that needs replaced on their strobe Edge bar. I had the captain call to one of his officers up there and get the model number off the sticker on the bottom of the bar and they gave me J(?)368000, which tells me nothing. I also don't know if it's a straight or a J-tube corner module.
Are the corner modules pretty much universal between the edge series? I am NOT an edge guy but I know there are a ton of you on here who are and can probably help me out.
If anything about the J368000 number can point any of you guys into getting me a part number for the replacement corner strobe assembly, I would be forever grateful. I don't think it's particularly important if a J-tube gets replaced with a straight tube, as long as they fit in the same spot.
Pete L.
Virginia (south/central)
The older edge stuff is all over the map..........I have a bunch of older edge stuff.
A pic would be super helpful. We might be able to fix you up, I know I could for short money ;)
-Pete
Ben E.
Iowa, USA
That's the problem, the car is 45 minutes away, and nobody up there knows anything about their equipment. Hoping not to have to drive up there just to see what model bar it is.
Ben E.
Iowa, USA
I got lucky and had a service call near this PD today so I swung by. It's an Edge Ultra.
May 25, 2010
7,072
Tunkhannock, PA, USA
With the space that combo reflector takes up it would be a corner module and a 400 then extra room... That is a 4X3 head which are slightly smaller than the 400s...
Ragnarok
