Strobes N More Dual Color E6 LEDs-SOLD
zackvv
274
Bergen County NJ
Two used Strobes N More Dual Color E6 LEDs, Blue/Amber with "L" Brackets.
$85.00 SHIPPED
The Strobes N More E6 Series is here with light output and features second to none. The E6 features 6 incredibly bright 1 Watt 3rd Generation LEDs. The E Series feature 21 built in Flash Patterns and are fully synchronizable with other E Series lightheads and feature a Dual Color Option. The E Series are fully encapsulated, which makes them 100% waterproof and vibration resistant. Designed by professionals for professionals the E Series are designed for primary warning, not "auxiliary or secondary warning" like so many other similar lights sold today. The E4 Series lights offer greater flash pattern selections, superior light output, synchronize capable, in an easy to install flush mount design. Optional Single Mount available below can be used to mount the units behind a grill, on a rear deck, push bumper, or from a headliner.
Dual Color! These new E6 lights feature dual colors which means you can run them in your choice of 2 separate colors completely independantly of each other. For example if you volunteer at the local fire department and use Red lights to respond to a fire these lights will do that. If you also plow snow on the side and need amber lights these lights will do that with a flip of a switch. They will also do have and half so you can run red and amber at the same time as well. Choose your color options from the dropdown below.
Features:
21 Flash Patterns
Synchronize with other E Series Lights
SAE Rated
All Aluminum Single Mounts available
Weight .2 Lbs
Dimentions L 5.95" x H 1.25" x D 1 "
Completely Waterproof
12/24 Volts DC
GSPS629
