Switch Wiring
07GD SFD
Senior Member
1
VT
Can anyone tell me how I'd wire this switch? Where would power come in, go out, ground, etc. Thanks.
Does it have a light in it? If not then there isn't a ground.
Power comes in on the center post, and the output is the outside post. That switch has 2 sets of contacts so that you can switch 2 different loads and sources off of it. The way your holding it there is a left side and a right side.
Paul
As much as I agree that it is likely a DPST switch, the only way to be sure is to test it with a multimeter or test light.
Or, if it is a Carling, the part number is on it. Their website ( http://rocker-switches.carlingtech.com/index.asp ) should have enough info for you to determine exactly what that switch is.
Thanks guys.
If I decide to only have one load off the switch, do I need to supply power to both posts?
07GD SFD said:
Thanks guys.
no. one side is in and out and the other side is in and out
but to be 100% sure. grab your DMM and shoot out continuity between the blades with the switch in the OFF and in the ON position
I shoot out every switch, even brand new ones that i specifically order. b/c people make mistakes
TNConstable
