T3 Bike Lights
Phillyrube
Flatistan
Idiots in horlando area made motorcycle riding dangerous, so I gave that up. Pedal power on two wheels, and that's worse. Even riding on the sidewalks sucks.
So, I decided to mount some Feniex T3s I had for another project on my 18 speed.
White T3 mounted to an old piece of bakelite.
Red T3 mounted to a piece of plastic. I used panhead screws to mount to the base to the reflector mounts, and the Feniex provided mounting screws for the T3s.
Ran the wiring through some 3/8" loom, to a generic chinese battery pack, using 18650 batteries. It also has a USB plug if you want to power a GPS. Heatshrink the positive wires, left the negative bare so I can change patterns if I want.
Could not get a photo of the white LED but you know what they look like. If need be I can change the front light to a steady if I need a headlight, but I use a Solarforce host with an 18650 battery, and Vinh custom head LED for a headlight. I can make that pulse or flash SOS.
Now, this is Floriduh, so ll I have succeeded in doing is make myself a target!
Reactions: Sparky_911
Sparky_911
Supporting Donor
May 15, 2013
2,658
Central Illinois
I added a T6 to my Harley last year. Works great. Bet you could get a full 8 hrs of night rides with that get up before needing to recharge. T3s draw like .4amps on steady burn.
Reactions: Phillyrube
Caldwell205
