Trouble with Triton EL13 A-1 flasher
Tomhae
121
Roseville, CA
Hi folks,
I recently purchased a heavy duty Triton EL13 A-1 alternating flasher to replace the faulty canister flasher in my old Smith and Wesson bar. When I installed it it just makes a buzzing sound and one light stays on steady. I also had similar trouble when I was bench testing it with different lights. The unit has three prongs labeled "L", "L" and "X". From what I can guess, the two L's are for the lights you want to alternate, and the X is 12v positive. The unit does not have a ground wire or any ground point that I can determine. When testing I grounded the lights, wired each pos light lead to one of the "L"s on the flasher and put positive 12v to the X lug, and got the same buzzing effect with one light steady on. I searched online for some time, and read that it buzzes when wired wrong, but I'm out of ideas. Any help would be greatly appreciated.
Thanks, Kevin
Richard P
1,031
Sudbury, On
Tomhae said:
Hi folks,
Thanks, Kevin
youre using a battery charger arent you"?
Richard P
1,031
Sudbury, On
Tomhae said:
Yep! Sounds like you have a theory, although I'm not sure why that would explain it not working in the S&W bar...
I have an answer lol. electronic flashers dont like force fed amperage. battery chargers force, 2 amps, force 5 amps, 10 and so on. flashers need to take their respected amps. used a battery, itll work.
Tomhae
121
Roseville, CA
So I tried powering the setup directly from a battery, and it worked using a federal signal flasher, but not the Triton. I guess there is a possibility I burned it out already with the battery charger. Is it something to do with new solid state flashers? The flashers in my old CTS and Aerodynic bars have always worked on the battery charger.
Richard P
1,031
Sudbury, On
The old thermal can flashers quite often worked on chargers, newer electronic and solid state dont like chargers one bit
timmy
97
Southern California
Tomhae said:
Hi folks,
Thanks, Kevin
I had a problem with a flasher unit when i was using my battery charger as a power source. it drove me crazy and i even bought a replacement flasher unit. once i switched to a better power supply (i really should have just tried a battery) the problem just went away. in my case the lights alternately flashed like they should but it was way to fast and the lights didn't even have time to come on fully.
just a thought
timmy
Clarence H
1,546
USA Twin Cities Minnesota
Most battery chargers do not produce "clean" DC power. A lead acid battery can absorb the "ripples" as it is charging, an electronic device cannot. A battery charging pack is a better option.
Clarence
StormChase85
