Unitrol 8000 Control Head
theroofable
1,379
New Jersey
HI,
I want to use the accessory switches to turn on a few things seperately than the slide switch. All I have to do is run a wire from the (+) output on the terminal strip to the ARM and the accessory to the NO for each switch correct? Then when the switch is activated(green light) it should turn on?
Thanks.
cajunblitz
1,217
Saint Martin Parish LA
theroofable said:
HI,
Thanks.
Yes, that is correct. ARM is also the same as COMMON, like the (30) input on a relay.
ddd
