Hoff
I have a Code 3 V-Con (a 3692 I think) that has what appears to be a loose connection on the hard wired PA. When the volume is high you can hear the PA cracking as the wire is moved. Also when you turn the TDs or alley lights off quickly you can hear the speaker "pop" like you keyed the PA mic. Is this something that I can attempt to repair myself or should this go back to Code 3?
