If you do some looking around, you will be able to find one much cheaper.HearseGuy said:Wailer,
Thanks so much for the prompt info!
Without knowing the worth of this exact model i figured id check with the guys who know their s#!t!
This isn't mine. A local person wanted to trade it to me. He is asking $200. That is his bottom dollar. There isn't a mic or bracket.
Thanks again bud.
$50 for a good Interceptor isn't all that bad. .
Wailer said:For a series 2E. 2Es are a dime a dozen.
The PA10, PA20; and PA20A series 2B, 2C, and 2D are worth a lot more. The earlier versions aren't as common as the 2E.
Skip Goulet said:while the early Directors mounted straight to the dash w/o a bracket
Black Hoe said:Even though series 2E's are the most common, keep in mind that they are the only Federal Interceptor's that are capable of the infamous "in-between" siren tones.
Wailer said:The PA15A series 1B, 1C, and 1D are the only versions with the welded on mounting tabs. All other versions of the Director have a removable mounting bracket like the Interceptor.
The PA150, PA170, PA200, and PA1000 have the same siren oscillator circuit as the PA20A 2E. They can do the 'in-between' tones too.
