Vehicle Partitions/Cages
medicop88
221
Rhome, Texas
Does anyone know if vehicle cages/prisoner partitions have to be vehicle specific, or is there a model that can be moved from different types of vehicles? The idea is that we can reuse them in newer vehicles (such as old style chargers to new style). Any help would be appreciated.
twodogs603
1,196
Norfolk,VA
I have swapped the ProGard sheilds between older Impalas, Intrepids and Crown Vics. The shield is the same, you just need a transfer kit for the specific vehicle. However the shields for the newer Impalas, Chargers and such Im not sure about. They have a different way of mounting in those vehicles.
MPD 818
1,317
Murfreesboro TN
I can only speak from experience about Setina because that is all I use. Setina seems to have finally gotten the actual cage part to be universal, and all you have to change are the side pieces and mounting brackets.
I have seen installs that modify a cage out of one vehicle to fit in another vehicle. I do not like doing that for many reasons, the main being that if you do not use the right mounts/brackets/cage etc for a specific vehicle and you get in a wreck you run the chance of having a large heavy piece of steel flying around the inside of a car.
woobatu
