Vision Lightbar mounting
Mrlunchbox
Premium Member
1,293
Central, MA
Hey guys, has anyone ever mounted a vision lightbar on a Ford Explorer Sport Trac? I am thinking of getting one for mine, but concerned how it might look. Would love to see some pictures if anyone has any! Thanks!!
Thanks for the pics! It looks like I wouldn't have to remove my roof rails to get it installed. The ends of the bad sit pretty high up off the roof.
Mrlunchbox said:
Does anyone know if the visions can be bolted directly to the roof of a car? IE not using gutter mounts?
Yes, they can. There is a hole in the middle of the mounting feet on either side of where the rubber mounts sit. You'll need four holes in the roof to mount it. I'd suggest using clear RTV silicone on the inside and the outside of the hole prior to installing the nut & bolts to prevent water leakage. Also use a nice big washer between the nut and the headliner of the vehicle to prevent the bar from ripping through the roof sheet metal.
wolfman
flo59641
