Hey guys-
OK first, let me be abundantly clear: This is NOT a discussion about jurisdictional color coding, color combinations, theories about what colors should be used where, etc, etc, etc...... So, now that we have that out of the way:
I just got my first FS Jetstrobe lightbar- Clear outer lenses, with colored filters in front of each lamp assembly, as needed. First, I was interested to see that the filters are actually attached to the outer lens, not the lamp assembly. This essentially means you have to place the filter in the outer lens "about" where you think it should go.... then slide it on, see if you were right, and adjust accordingly. Interesting concept.
But what I found more interesting- and thus the actual point of my thread: On my particular bar, the TD's had clear inserts in front of them (even though the outer lens is clear). So you are shining the TD's through TWO clear lenses. Why do they do that? My actual real job here in Las Vegas, is a Production Manager/ Lighting Designer for one of the Concert/Event venues here. In Live Production/Stage World, you put clear "gel" in front of a light, the reduce the heat output, so that the light energy makes it to the stage, without roasting the talent (although sometimes it would be nice if........ ahem.... I digress). Is this the same thing here? It just seemed weird to have/need that there.
It's not a big deal- to be honest, I took them out. I was just wondering if anyone knew the justification behind them.
Cheers.
Cheers.
