Whelen 2009 Liberty lightbar with WECAN
Fireman_c
8
Ohio
I am trying to get a liberty 54" lightbar to work. I have programmed a brand new WEcan module but I get nothing when I put the green wire to 12 volts. All the light heads have 12 volts all the time but I do not have continuity in the ground
NoLimitSquads
335
Minnesota
What green wire are you putting power to?
Did you program the control point? Or are you using default programming?
Power and ground to light bar?
The WeCan wires are hooked to the lightbar correctly? Green to green, and grey to grey?
Fireman_c
8
Ohio
I have programmed the WeCan controller in everyway possible. Gray to Gray Green to Blue
ffjwhite
Bombay, NY
If its a true wecan it should be gray to gray and green to green. Just to make sure, you have 2 wire harness from the bar? 4 wires in total?
Fireman_c
8
Ohio
The 3 wire control wire coming from the bar is gray, blue and shield. The bar is a Liberty SW2RRRR
RS485
Supporting Donor
Aug 5, 2019
370
Central MA
You should probably open the lightbar up and verify what I/O board it has and go from there.
If it is WeCan, you might want to check out this thread -- some folks had problems using newer "Command" with older lightbars and the posted .BXR file seemed to help.
Reactions: Tony P
Fireman_c
8
Ohio
It says it's a SC Liberty I/O Assembly
RS485
Supporting Donor
Aug 5, 2019
370
Central MA
That would explain why it doesn't work :)
You can either go the SC route:
1. MPCxx controller
2. USB->RS485 cable (just a USB cable if MPC03)
3. programming software ( See "Serial Communication Programmer" here -- also see this post for a tip on how to get it working on modern Windows )
There is a listing on eBay right now for someone who'll sell you an MPC01 and include programming FWIW
-OR-
Maybe replace the SC board with a WeCan board. Other folks here can probably make the best recommendation with respect to the most suitable board and what it entails (may need wiring harness).
Reactions: Ranger-Services.com
Fireman_c
8
Ohio
1. MPCxx controller
-OR-
Other than a new power cable can I use the existing 12 pin cable that feeds all the lightheads? There are two of those in this bar. One for front heads, one for rear heads.
RS485
Supporting Donor
Aug 5, 2019
370
Central MA
If I understand you right, you're talking about the harnesses which go between a group of six heads, and a port on the SC I/O board. The corner modules have their own eight-contact plug in there too.
I think you'd be better off replacing the SC I/O board with an "LC" (Low-Current) I/O board (and possibly harnesses).
Connecting directly to the LED heads is outside of my experience so I can't recommend it.
JohnMarcson
May 7, 2010
10,971
Northwest Ohio
woobatu
