Whelen 900 series halos + flasher
Pimp
Veteran Member
1,872
204
Louisiana
I have an upcoming project where I'm going to be mounting some Whelen 900 series halogens on a rig and thought that a simple HLF would work to flash them. I'm going to be alternating 1 clear with 2 red. Any suggestions for a good flasher or HLF that would be able to handle the amps? I'm looking for CHEAP! This is coming out of my pocket for my VFD.
What would the proper wire size be for these? Fuse size?
Suggestions? Pointers? Tips? Advice? Personal experience? Testimony? Pics? Vids?
[Broken External Image]:http://www.txemergencyvehicle.com/FOR SALE/Whelen900HALO.JPG
They use the same 55 watt halogen bulb as any lightbar. I would fuse it with a 20 amp fuse as you're looking at 4.72 amps per head. For a flasher, just a cheap wig-wag unit will work. Sirennet has a Whelen one for $30. http://www.sirennet.com/whuhf2150.html Another thought to consider: do you have a junk yard nearby with old ambulances or fire truck? I got an ambulance flasher out of a junked truck for $10. A little over kill for your application, put the price is right!
Just a Basical EL13a flasher from like napa.
It just alternates between the two outputs. Red on side, clear on the other. It's rated at like 20 amps or something too. And they should be around 20 dollars or so and should be easily available.
Burt, get with me I have brand new sound off heavy duty flasher that can flash a set of hlf
and grille lights at the same they plenty heavy duty. I'll get some pictures for you,
Just pay the shipping and I will donate them to your fire dept.
#1- Alternate/6, 100 percent solid state,will alternate vehicles highbeam headlights, grille lights and deck lights
at a constant flash rate 2.5 flashes per second
I have six of these units.
Jim Rogers
deputychief301
AnotherMike
