I have a Whelen 994PA 4 beam, rotating halogen beacon/siren speaker combo.
I applied power, I got spin and no lights. So, I tested the bulbs individually, they work.
Ok, so I figured we must have a wiring problem. I turned over the motor mount tray and found this:
The terminal/spade connector is supposed to (I assume) connect to the bottom of the spinning shaft, to deliver power to the bulbs. I touched it in this fashion and WALA, it worked. At this time the metal part that was in the terminal/spade connector broke off.
It appears as if the terminal/spade connector may be burned/melted.
Here's my problem. The connector piece doesn't stay on the shaft any more. It appears that the hole is drilled out too big. I am possibly about to sell this light and want to know how I can properly repair this. Other than this issue the light looks and functions great!
