vsfd341
how can I hard wire the light and still be able to change the flash patterns on the whelen avenger
TritonBoulder47 said:Ground the unit, run the power to your switch, and run your pattern wire to a momentary switch...
vsfd341 said:there are three wires inside the black sleeve i have a black,white and green i all ready have a switch from and light that only have 2wires coming out of it
Brad519 said:Probably easy to figure out but this stuff is mostly Greek to me.
If I cut the plug off I will have 3 wires. 1 power, 1 ground, and 1 to pick flash pattern? Is that correct?
Sorry if this question is elementary as I'm not a install guy. I'm just a cop and we're not known for your electronic genius :haha:
