The ones for the 5200 have no 12 pin connector. The ones for the 8000 bars have the 12 pin connector. It appears that the one in the pic is for a 5200 as I see no 12 pin connector. FYI.... there is NO way to modify one to make it a 2 outlet supply. One could use a 8000 for a 5200, but not the other way around. I hope that helps. If you have any that have the 12 pin connector for the 8000, I would be interested in getting a few. Also, whatever you do... NEVER reverse the polarity on them. It will render them USELESS and unrepairable in less than 1 millionth of a second.
