whelen dominator traffic advisor wire question
ask80
361
OC,CA
hello. I have a 8 head whelen dominator traffic advisor with flashing ends. is there a way for the warning pattern to flash without the ends flashing? the left, right, and center out can flash without the end lights on. when i hook up power to the red the warning pattern and flashing ends go on. thanks
Nolines
1,681
Margate, FL
Tir3 or Linz6??
Yes According to the install guide... turn off the switch 4, or find the orange wire and remove it from power if not already on its own switch.. the install guide isnt really specific and im not sure how you are controlling your dominator... but I included it..
Says to use a TacLD1 traffic advisor controller with additional switch for the flashing end lights..
Low Power / Orange Wire: If your lightbar is not equipped with End Flashers the ORANGE wire will activate Low Power.
This feature steps the lightbar down to low power for nighttime use. Applying +12 volts to the ORANGE wire holds the Traffic Advisor in low power mode until voltage is removed. (a toggle switch is recommended).
  • 13899.pdf
ask80
361
OC,CA
linz6. i saw that attachment before but doesn't work. when i hook up power to the red (switch 1) with no other wires on, it's supposed to be TA flasher only, I assume? and if i hook up red and orange it's supposed to be TA flasher and end flashers? maybe i read it wrong. when i hook up red and orange only the end flashers flash.
Nolines
1,681
Margate, FL
Yes I read that, Hmmm what about the scan lock white wire?any power to that? for pattern selections of the ta flash... maybe whatever it was set to is burnt out and in need of repair.. trying to obtain another pattern may get the ta flash to work.. Orange by itself will always get the end flashers to flash..
ask80
361
OC,CA
the white works fine to change the patterns for the TA and end flashers. i'll see what whelen says. maybe that is the normal function...
Nolines
1,681
Margate, FL
well it said red alone and the ta should work whatever the default is for scan lock so without the orange that should work... thats why I wondered about the default setting if it was having an issue..
Caldwell205
