Whelen Euro-1 siren?!
The last tone is essentially a powercall-whoop siren. I never would have expected it on a euro siren. The powercalls (or "warbles" by other manufacturers) are typically used in conjunction with the mechanical Q-siren, but some areas (ie some counties in Pennsylvania) use them as standalone sirens. IMHO the powercall tone is effective because it doesn't get muffled up by the mechanical siren as much as some other electric siren tones & because it grabs attention of ppl that have never heard it before and give the WTF? look/response lol. I honestly would've gone with the basic whelen wail/yelp/hyperyelp, but that's just me
Thanks for sharing.
So an interesting note, I googled the part number in the picture to see if I could find an install guide and the results turned up the Howler, which appears to use the same housing as this euro-1 siren. Makes me wonder if there are settings in the unit to change the output or if they are just using the same housing with different internals???
The Powercalls aren't just a PA thing, they're also wildly popular in Maryland, DC, and Virginia. We use a Powercall on my engine at work in fact.
I never said that they were just a PA thing; I just use PA as a single example of a place where they're popular.
It is supposed to emulate the 'warble' tone of a General Electric Power-Call/Siren. The GE Power-Call/Siren was introduced in the mid-1960s and was in production up until the 1980s. It is now a collector's item.
I think the Powercalls are popular all over. Just try buying an original G.E. Powercall off Ebay,etc. I have one of the little Whelen Gamma-2s and it has the Powercall sound and I wouldn't part with it.
I just installed a ALPHASL in my car last week. I changed the 3rd tone from Piercer to Powercall as soon as I installed it. I also have an original GE Power Call in my collection as well. Great sound that travels well in an urban environment.
Well, at least you've got a real Powercall, Mike. It's the one siren I've never had.
SireLite said:
It's probably a reprogrammed Alpha.
Yes, this is Alpha in European version, siren have specjal tone for France, UL, Germany, Holland, etc.
Basic switch is the same, but Euro1 have additional options:
Green - Cycle switch
Blue - Siren in use (icon)
Red/Wht - output 12V+ for controll switch
Org - Brn - Yel - Speakers + - +
Blk - Red - Power - +
Rest wire is the same as Alpha remote
Euro 1 have 49 diferent tone:
0. Tones off **
1. Wail 750_1570_12cm . . . . . . . . . . . . . 750 - 1570hz 12c/m
2. Yelp 750_1570_158cm . . . . . . . . . . . . 750 - 1570hz 158c/m
3. Hilo 550_650 . . . . . . . . . . . . . . . . . . . . 550Hz for 1s . . . . . . . . . . . .650hz for 1s
4. Airhorn-Hi . . . . . . . . . . . . . . . . . . . . . . variable composite*
5. Airhorn -Lo. . . . . . . . . . . . . . . . . . . . . . variable composite*
6. Piercer 750_1570_800cm. . . . . . . . . . 750 - 1700hz 800c/m
7. Mechanical simulated . . . . . . . . . . . . . 4.4c/m
8. Ambulance: Netherlands & Holland . . 635Hz for .90s. . . . . . . . . 800hz for .90s
475Hz for .90s. . . . . . . . . 800hz for .90s
9. Airhorn Hilo 30cm . . . . . . . . . . . . . . . . variable 1s. . . . . . . . . . . . variable for 1s
10. Alt Wail 500 1650 10.5cm . . . . . . . . . 500 1650 10.5cm
11. Alt Yelp 500 1650 255cm. . . . . . . . . . 500 1650 255cm
12. H-Wail 850_1700_15cm . . . . . . . . . . . 850 - 1700hz 15c/m
13. Wail 600_1200_16cm . . . . . . . . . . . . . 600 - 1200hz 16c/m
14. Yelp 600_1200_267cm . . . . . . . . . . . . 600 - 1200hz 267c/m
15. Martin tone . . . . . . . . . . . . . . . . . . . . . hi/lo variable composite. . . . . . . . . same
16. H_hilo_composit_46cm. . . . . . . . . . . . composite for .65s. . . composite for .65s
17. Composite_tritone__17cm . . . . . . . . . 423Hz for .90s. . . . . . . . . 533hz for .90s
316Hz for .90s. . . . . . . . . 533hz for .90s
18. Pulsed yelp/airhorn . . . . . . . . . . . . . . . mixed tones
19. Triton 475_635_800_45cm . . . . . . . . . 475Hz for .337s. . . . . . 800hz for .3337s
635Hz for. . . . . . . . 337s800hz for .337s
20. Standard . . . . . . . . . . . . . . . . . . . . . . . 450Hz for .909s. . . . . . . 600hz for .909s
21. Denmark . . . . . . . . . . . . . . . . . . . . . . . 450Hz for .50s. . . . . . . . . 600hz for .50s
22. Sweden . . . . . . . . . . . . . . . . . . . . . . . . 530Hz for 1s . . . . . . . . . . . .700hz for 1s
23. Police (Austria) . . . . . . . . . . . . . . . . . . 430Hz for 1.2s. . . . . . . . . 575hz for 1.2s
24. Ambulance (Austria) . . . . . . . . . . . . . . 400Hz for .75s. . . . . . . . . 530hz for .75s
25. Canarias . . . . . . . . . . . . . . . . . . . . . . . 420Hz for .306s. . . . . . . 516hz for .306s
26. Police (Netherlands) . . . . . . . . . . . . . . 600Hz for .455s. . . . . . . 800hz for .455s
27. Police (Holland) . . . . . . . . . . . . . . . . . . 600Hz for .909s. . . . . . . 800hz for .909s
28. Guardia Urbana. . . . . . . . . . . . . . . . . . 550Hz for .441s. . . . . . . 750hz for .441s
29. Deutschland . . . . . . . . . . . . . . . . . . . . 432Hz for .75s. . . . . . . . . 575hz for .75s
30. Alemania . . . . . . . . . . . . . . . . . . . . . . . 362Hz for .75s. . . . . . . . . 485hz for .75s
31. Gendarmerie(France) . . . . . . . . . . . . . 430Hz for .545s. . . . . . . 735hz for .545s
32. Police (France) . . . . . . . . . . . . . . . . . . 430Hz for .545s. . . . . . . 575hz for .545s
33. Fire(France). . . . . . . . . . . . . . . . . . . . . 430Hz for 1.1s. . . . . . . . . 483hz for 1.1s
34. UMH(France). . . . . . . . . . . . . . . . . . . . 430Hz for .545s. . . . . . . 650hz for .545s
35. DIN 14610 . . . . . . . . . . . . . . . . . . . . . . 450Hz for .75s. . . . . . . . . 600hz for .75s
36. Fire/Ambulance (Italy) . . . . . . . . . . . . . 392Hz for 1.0s. . . . . . . . 660hz for .167s
37. Police (Italy). . . . . . . . . . . . . . . . . . . . . 466Hz for .75s. . . . . . . . . 622hz for .75s
38. Ambulance . . . . . . . . . . . . . . . . . . . . . 420Hz for .167s. . . . . . . 516hz for .167s 420Hz for .167s. . . . . . . pause for .300s
39. Ambulance (France) . . . . . . . . . . . . . . 420Hz for .167s. . . . . . . 516hz for .306s
420Hz for .167s. . . . . . . . pause for 1.5s
40. Ambulance (Netherlands) . . . . . . . . . . 450Hz for .938s. . . . . . . 800hz for .938s
661Hz for .938s. . . . . . . 800hz for .938s
41. Composite_hilo_375_500_46cm. . . . . 375Hz for .650s. . . . . . . 500hz for .650s
42. Composite_hilo_375_500_92cm. . . . . 375Hz for .325s. . . . . . . 500hz for .325s
43. Police (Netherlands) . . . . . . . . . . . . . . 493Hz for .75s. . . . . . . . . 660hz for .75s
44. Fire (Austria) . . . . . . . . . . . . . . . . . . . . 392Hz for .50s. . . . . . . . . 523hz for 1.0s
392Hz for .50s . . . . . . . . . . . . . . . . . . . 523hz for 1.0s
pause for .50s
45. Rescue (Austria) . . . . . . . . . . . . . . . . . 523hz for .50s . . . . . . . . . 392Hz for 1.0s
pause for .50s
46. Police (Austria) . . . . . . . . . . . . . . . . . . 392Hz for .25s. . . . . . . . . 523hz for .50s
392Hz for .25s. . . . . . . . . 523hz for .25s
392Hz for .25s. . . . . . . . . 523hz for .75s
pause for .25s
47. Pistensignal . . . . . . . . . . . . . . . . . . . . . 600hz for .75s . . . . . . . . . pause for .75s
48. Fire-Brigade (GB) . . . . . . . . . . . . . . . . 430Hz for .545s. . . . . . . 483hz for .545s
49. Yelp 700_1200_162cm . . . . . . . . . . . . 600 - 1200hz 162c/m
scannerdude
