okc_f150
I have a converted Edge 9000 bar with Whelen 400s. All blue front with custom made Feniex T6 Spot dual takedowns, Whelen 400 halogen alleys and a red/blue split rear.
The rear 6 have been wired to a separate harness for control from a separate flasher, or the wires can be put back to the Whelen harness and used as 2-wire TA and flash.
The rear 400s have been spliced so that they are not split flashing. These can be easily set back to normal if you want to flash the bottom separate from the top.
The takedowns were a custom piece from a member here and myself. Two Feniex T6 spot dummy modules are mounted to 400 blank plates. These things are pretty impressive, they blow the blue 400s out of the water.
Lenses have been polished and cleaned up.
Full length power/ground cables, control wires and TA harness.
Whelen headache rack mounts attached.
Asking $350 shipped for this bar. If you don't want the Feniex TDs, I'll make it $300 shipped.
Video here
Video here
