dockdoc
Hi all - I have an HHS2200 which has had a single siren speaker for a while. I've found that I get inadequate warning with it so wanted to add some more power.
I purchased another siren speaker (Whelen SA315) to match the existing one. Followed the wiring diagram which has you tap it into the existing wire for the speaker, so both speakers come off the same wire from the HHS2200.
Is that all there is to it? I don't see anything in the manual about what the output should be, seems odd that you'd just add another 100W speaker tapped into the first one. Does this unit put out 200W that way?
I must say I don't notice much difference in volume with the second speaker, so just trying to make sure there's not something I'm missing...
