Whelen howler amp
Emdadur5
2
New york
Need help with a Whelen Howler amp its the silver one + CORE setup. My Howler works perfectly fine for the first time, but after that pressing AH only gives the normal air horn. Howler doesn’t sound on 2nd time I have to turn the Howler enable switch (SW19) OFF and back ON then the Howler will work again. Anyone had this issue n how it fixed
The old style howler amp just isn’t as user friendly as the new WCX howler amp. Your howler has two activation inputs. I would leave one hooked up how you currently have it, and the other, I would connect to an output from your Core. Have the airhorn from your Core activate the alternate howler activation input. If the Howler is important in this setup, I would look into getting a WCX amp, then its pretty easy to get it to work however you want.
Upvote 0
BlueGooseFPIU
