PTRJason
I tried searching but I do not think anyone has came up with it, or done it.
What I have is a 7 lamp LIN-6 Inner-Edge, with the MR-11 takedowns.
Has anyone switched out the MR-11 for the led takedowns, if I can find some really really cheap, or even try using LED MR11 style lights. I am not really looking for them to use as takedowns, as The MR11 halogen lights suck as it is. My reason is two fold, one I want to add a crisp white wig wag to the bar, with instant on and instant off, and not have to worry about the power up of the halogens. And two, the fan that is used for cooling, is either going out, or just noisy as hell sometimes, so I want to be able to remove it, or hook it so it comes on with the steady burn LED LIN6, as that heat sink gets hot!
It will be going in an Expedition, so the takedowns will kot really be useful that much anyway, as the highbeams are in the rear window of most vehicles, and they are bright. Will be even better when I get a spot light installed, and also put a leveling kit on the truck. When time and funds allow.
I do not plan on changing the take downs for a while, too broke right now and still awhile away from the install for the entire truck, but lookikg at ideas.
I was looking at it when I bought a few bicycle light systems, a BLT and a NiteRider, both using halogen MR11, but looking at LEDs for longer batter life and a crisper throw.
I guess what I am wonder is, will the three led take downs from a Liberty work forna swap? I think that is what is in the newer Inner-Edges?
Any experience with aftermarket LED MR11s?
