If you don't have the software disc you will need to take the following steps:
Download the WeCad builder and WeCan 6 software on Whelens site in the download/literature section of the site.
You need to use WeCad and "build" your lightbar. Once built you will need to export it as a .wbr file to your desktop or easily located file folder.
You need to open up the WeCan software and highlight "lightbar" and select continue
on the next screen select "import lightbar" and select the .wbr file you created in WeCad
Connect the WeCan module to your PC via USB
There are 18 inputs up above. I believe if you were to hold the module the wording on the pn label should be orientated so you can read it. This will orientate you to the 18 actual wires coming out of the module to correspond with each output on the computer screen
Select the 1st output you want to use and then go down to the actual color coded (based on the bar you built) and select the lightheads you want active on this input wire
then select pattern via the dropdown box
then select whether you want them sync, delay etc...
then you move on o the next input wire and so on and so forth
TD/SB/SCENE is simply selecting the lightheads you want to steady burn and selecting "on" in the pattern drop down box.
Cruise mode has its own screen. Pushing the button in the center that says cruise will access the cruise mode.
Be sure to drag the 2 wire
TA over from the toolbox at the bottom left of the WeCad build screen to have
TA function when custom programming your WeCad module.
Good luck and HAVE FUN!! That's what it's all about!!
