whelen liberty 1 WC BRX file
Cesar198660
7
2
washington
hello i hope someone can help me out here , I want to converty my liverty LFL to a wecan. I plan on swapping out the board but i don't see any liberty 1 in command . all i see is liberty II and liberty WC with tuo TA. anyone know how i can be able to program my bar in command . This is the board im planning to get
Hope this helps:
If the other file that was posted doesn’t work, you can create your bar .bxr file in WeCad.
Hope this helps:
i download it and when i upload it to command nothing happens. so when i open it through adobe i get this message . any suggestions ? do i need a specifc progrma to be able to open this
In Command, you should be able to "Import" the .BXR file (click on the "Import Device" button.
Yes I’m in the import when I go to where the file is it’s not there but when I change the file type to all files as you can see in the 2nd picture it pops up. Once I upload it to command nothing seems to happen. I don’t know if I need to make it into a lightbar file like it says in 1st picture
I think you first need to extract the file. IRRC, I had to "compress" the .BXR file in order to be able to upload it so the actual attachment is a ".zip" file.
So using the Windows explorer, you first have to right-click on the file you downloaded (a menu should pop up), then click on "Extract all".
The .BXR file should then be extracted.
HTH
o
HTH
okay i got it to work,thank you so much
Reactions: tsquale and RS485
Edit: For liberty 1 .bxr files go to Whelens website. On the drop down menu, click on downloads. If you scroll all the way to the bottom, you will find a download titled “discontinued lightbar templates.” That is where you can find all of the old lightbar files. Then you can open them up in WeCad, configure them how you want, then export to command. I see that you already got yours figured out, but this might be helpful for someone in the future.
Reactions: JohnMarcson
I appreciate that being pointed out. If you offer a lightbars called legacy, you should really support your discontinued "legacy" products, and so far Whelen is doing just that. Thanks for pointing this out.
Sfelock
