Im wanting to know if it can be done...I'm wanting to use the Cruise light function at full brightness instead of low power glow that they are set to...? Thanks!
If you're able to control each pair of light heads individually then what about connecting those corners to a relay or ULF 44 and set the secondary "flash pattern" to steady burn and the primary flash pattern to a flashing pattern?
