whelen mini justice LR11 led alley lights question
jayzce
175
Philippines/Manila
I have a mini Justice in all blue and i was thinking of spicing it up a bit with alley lights since Whelen tech support told me i can't install takedown lights on them without changing the boards and a lot of things. Although i can go and put some LR11 alley lights on them without changing any wiring or boards. Only a couple of question regarding the LR11 on my Justice parts list.
Here are the parts
Part # 01-026A752-00 SUB ASY, LR11 WHITE JUSTICE 45lm
Part # 01-026A752-01 SUB ASY, LR11 WHITE JUSTICE 100lm
Part # 01-026A752-30 SUB ASY, LR11 20 DEG WHITE 45lm JUSTICE
Part # 01-026A752-31 SUB ASY, LR11 20 DEG WHITE 100lm JUSTICE
Is the lm means lumens? so the 100lm is mor ebrighter than the 45lm?
What is the 20deg? they are 20deg on the x axis when installed on the lightbars?
Any help would be appreciated. I want a straight alley lights that would light up my sides when my lightbar is turned on.
Thanks in advance
The degree designation means that the lights can be aimed. The brackets are slotted so you can loosen the mounting screws and twist the head to aim a certain way. If you want it straight, just secure it straight.
As far as the output goes, they used to advertise 2 different intensity LR11's in the bars. Now they're all the intensity 2, which are brighter. I wouldn't bother with the lesser bright models.
As far as "changing boards", etc, I have never opened up a mini justice (we don't see many up here), I can't help you there...
thanks for the reply.
so i guess I'd just be better of with the
I guess this is the stright aim and with the brighter leds.
Thanks again :)
So how did the alley lights install in the mini justice was it easy to do or was there alot of mods needed to get it to work.
Thanks
Thanks again :)
T.Simmons
