SOLD Whelen, Rigid, Federal Signal, JW Speaker, Sound Off, Havis, Tomar, Rear View Safety, etc... New and Demo items... SALE and CLEARANCE pricing.
Git Lit
13
Waukesha, WI
2/6/2023 UPDATE:
My sincere apologies, but I am deleting this ad. It appears as though a coworker moved many of the items in the below inventory and now I can't find many of the specific items people are inquiring about. I just don't have the time to go through these items again, or the other 100's, and 100's of additional items I haven't gone through yet. It's just been too time consuming. My sincere apologies to everyone.
All items sold as is, and may not come with a warranty, depending on the date code/manufacturers warranty. Pricing does NOT include shipping. Or items can be picked up in Waukesha, Wisconsin. Most items are new. Items are listed by color, and then in miscellaneous section. Please reference the color and item number, if there is one (#__) listed. I can reply with picture of the item(s). You will receive a faster response if you email me at NicoleS@GitLit.com.
AMBER ITEMS
Qty 1, 68-1182319-10, Whelen Lens, Amber Optic Halogen, NEW. our cost $35.88
Qty 32, 68-1963588-10, Whelen Lens, Amber Vertical Optic, NEW. Our cost $9.90 each
Qty 2, 68-3183573-1S0, Lens, Amber Non Optic with seal, NEW. Our cost $30.00 each
#4 Sound-Off Signal Ghost Light, Model EGHST1A, Amber with Amber Lens, NEW
Qty. 2, $115 each or 2 for $200
#10 Whelen strobe light head assembly “F” beacons, Requires power supply, Amber with Amber Lens, NEW, Qty.2, $88 each or 2 for $140
#11 Tomar Microstrobe – Fork Lift Light, 470S-1280, With mounting bracket, Amber with Amber Lens, Used, Qty.1, $45
#14 Sound-Off Signal, ELB45BCLOAA, Permanent mount beacon, Amber, Qty.2, $135 each or 2 for $250
#15 Federal Signal Sentry Lenses, Model SY12F, 1 Red or Amber, 1 Red, 100 Watt Rotator, Permanent Mount, Qty.2, $45 each or 2 for $70
#16 Sho-Me Flashpoint, Model 12.6233, 360 degree LED light beacon, 1” pipe mount, NEW in box
Amber with clear lens/dome, $90
#20 Whelen LINZ6, LINZ6A, Amber, Qty 2, one with black surface mount, $20 each or 2 for $35
#21 Whelen, 01-026B030314A, Amber, Qty 1, $15
#22 Whelen TIR3 HORIZ, RSA03ACR, Amber, Qty 1, With black surface mount bracket, $15
#24 Whelen ION, IONA, Amber, Qty 2, $40 each or 2 for $70
$25 Whelen 2 Light Dominator Series, D2CC, Amber, Qty 1, $100
#32 Federal Signal Streethawk, Fully loaded, Amber, Used $150, (not sure if I still have this or not?)
#73 Soundoff Signal beacon, SAE J845, 4” beacon flat pipe mount, Amber LED with Amber Lens
Qty 9 Used $45 each or 2 for $70
Qty 1 New $70 each or 2 for 120
#91 Whelen Micro Max Beam Strobe, Micro Grill Master, 01-0380676-00, Amber with amber lens
Silver metal housing, rectangular, 4.5” wide x 3.25” tall, 4” tall with housing, Qty 1, $10
#100 beacon, Unknown maker, $5
#101 Starbright Model 917, Forklift light, Amber with Amber Lens, Used, Qty 1, $10
#102 Whelen 400 Series LED Steady Mix, 02-038345831AD, 3 Amp, Amber, Used, Qty 2
$15 each or 2 for $25
#109 Sound Off Signal SAE RIPST-00, Ground tail stop / turn, ECV061TY, Amber with Amber Lens,
Used, , qty 9, $10 each or 2 for $15
#110 JW Speaker, Model 271, Housing PA66-MR40, Vertical Mount Only, Amber with Amber Lens,
Used, Qty 3 with one extra bulb, $5 each, bulb $3
#120 Sound Off, ECV061TY, Stop/Turn/Tail, Amber with amber lens, Qty 1, New $10
#124 Sound Off Signal, LED 3 Mini Surface Mount, EL3SNA, Amber with clear lens , Qty 1 , NEW $35
#223 Tomar, RECT-25LSHPB-A, Amber with clear lens, NEW, Qty 1, $45
#224 Sound off Signal, ELUCMV-A, Amber, NEW, Qty 2, $10 each or 2 for $15
#226 Truck-Lite Co., Model 0708, Stop, turn, tail with metal housing, Amber lens, ,Used, Qty 2,
#227 Whelen 500 Series, TIR 6, Amber, Used, Qty 3, $15 or 2 for $25
#231 Federal Signal, Model GH1F, Series A, Amber, Used qty 2, $15 each or 2 for $25
#232 ?, Amber, Used, Qty 2, $5 each
#235 DOT lights, Amber, Used , Qty 4, $3
#240 ECCO, Model 6750, Amber beacon, Used, Qty 1, $20
#251 Whelen (in overstock), Model AVN1A Avenger, No longer made, Qty: several , $75
#303 is a Code 3, amber with metal cage. 50", LED or halogen?, specifics?, $5
GREEN LIGHTS
Qty 1, 68-1183581-40, lens, green optic with LIP 600. NEW. Our cost $35.40
#23 Whelen Vertex, 01-026B715-40C, Green, Qty 2, $40 each or 2 for $70
#218 Tomar
RECT-13LS-G
Green with clear lens
NEW
Qty 4
$40 each or 2 for $75
CLEAR /WHITE LIGHTS and SPOT LIGHTS and HEADLIGHTS
Qty 1, 68-2984063-30. Dome, clear optic. NEW. Our cost $61.27
Qty 2, D2CC, Whelen Dominator 2, TIR3 Super LED, Clear/White. NEW. Our cost $136.80 each.
Qty 7, P46SLCX, Whelen PAR-46 LED Spot Light 12V Smoke lens. NEW. Our cost $156.00 each.
Qty 2, P46WLC, Whelen PAR-46 20x60 LED Flood Light 12V. NEW. Our cost $109.00 each.
Qty 2, Rigid, 32221, Dually SL Spot. NEW. Our cost $118.92 each.
Qty 1, 547061, JW Speaker 8800 Series 4x6 LEDSAE/ECE projector Headlight/scene light low beam. 12/24V. NEW. Our cost $306.60
Qty 1, 547761, JW Speaker Model 90, 12/24V LED SAE/ECE Low Beam RHT Lamp. NEW. Our cost $171.30
Qty 1, SPA530-J20-TW-A, Fire Research Spectra, 20k Im 240 VAC, Twistlock SM, Ps. (Brow Light) NEW. Our cost $953.82
Qty 2, SPA900-Q70-W, Fire Research, Flood/Loading Light. NEW. Our cost $320.67 each.
#1 On Scene Solutions, LED compartment lighting, 10”, 73010, Qty 4, $12 each, Or 4 for $40
#2 Whelen Vertex, VTX609D, Qty 3, $40 each or 2 for $70, 3 for $100
#3 Whelen original Vertex, Qty 1, original “6 LED hideaway”, Clear with clear lens, $20
#4 Whelen 3” round LED, 3SC0CDCR, $30
#5 Whelen LIN3, 02-036C254234, RSC02ACR, Clear with clear lens, $35
#6 Whelen TIR3, RSC03ZCR, Horizontal, Clear with clear lens, $35
#7 Unity spotlight, 8547 model S04, 6” Round LED, $100
#8 JW Speaker Flood light, Unknown model, $20
#9 TecNiq T40, 4” stop/tail, $5
#43 TecNiq P04, Steel Head Heavy Duty Work Light, Flood, LED, With mounting bracket, P04-WBFP-1, Qty 1, $50
#44 TecNiq P02, Steel Head Heavy Duty Work Light, Flood, LED, With mounting bracket, P02-WBFP-1, Qty 1, $30
#49 Whelen Micro Pioneer, MPBB, Black housing, Qty 1, $150
#50 Whelen PAR36, P36SLC, Qty 1, $60
#55 TecNiq E10, E10-WSOO-1, Ground pump, panel light with stainless brkt, Qty 3, $50 each
#61 JW Speaker, model 526, Work light, yellow housing, 6” x 6” LED, With mounting bracket, Qty 1, $150
#220 Tomar, RECT-13LS, White, NEW, Qty 1, $20
#221 Tomar, RECT-13LS, White, Used, Qty 4, $15 or 2 for $25
#222 Sound off Signal, Model EL3SNW, White, Used, Qty 1, $15
#254 Whelen, Model RBKTHD2, Harley Davidson side crash bar mount for TIR3, Qty : need to recheck
#254 Whelen, Model RBKTHD3, Harley Davidson Rear crash bar mount for TIR3, Qty: need to recheck
$32 each
RED LIGHTS
Qty 1, D4RRRR, Whelen Dominator 4 TIR3 Super LED, All Red. NEW. Our cost $215.40
Qty 4, ICFR, Whelen Liberty II Lightbar lenses +1 corner filter red. NEW. Our cost. $3.60 each
Qty 12, ILFR, Whelen Liberty II + 1 long filter red, lens. NEW. $3.24 each.
Qty 14, ISFR, Whelen Liberty II + 1 short filter red. NEW. $3.24 each.
#9 Whelen M7, M7RC, Red/white, Clear lens, $100
#10 Whelen ION, IONR, Red with clear lens
#10A Qty 4, no brackets $65 each or 2 for $120
#10B Qty 1: Currently tinted (for low visibility in grill) $60
#10C Qty 2: custom surface mount brackets $75 each or 2 for $130
#10D Qty 2, with universal mounting brackets $70 each or 2 for $120
Total of Qty 9
#11 SoundOff Signal LED3, EL3SNR, Red with clear lens, Qty 1, With “L” mounting bracket, $25
#12 SoundOff Signal Intersector, ENT2B3R, Red with clear lens, Qty 1, $30
#25 Sound Off Signal 4500 Series LED, SAE J845, 4” Beacon, Flat Pipe Mount, Red with Red Lens,
LIKE NEW- used for very short time as display, Qty 1, $150
#26 Tomar Rect 79, L151, Red with red lens, Used qty 8, $15 each or 2 for $25
#103 Tomar Rect 25LSHPB-R, Red with Clear Lens, Qty ? – Used $20
#121 Unknown maker, DOT IST-99, Stop/Turn/Tail, Qty 1, Used, $5
#154 Whelen, DMP1S, Red with Red lens, Used, (bracket on it is broken), Qty.1, $25
#213 Code 3 Oscilater, Red lens, Used, Qty 1,,Qty 1 missing bulb, $15 each
#214 Code 3 Lens Cover, Red, Used, Qty 1, $5
#215 Sound Off Signal, Model ERDREBZ3RC, 4” Round Gen 3 LED, Red, NEW, Qty 2, $50 each or 2 for $90
#217 Sound Off Signal, Model EP2SSMDBR, Predator II, Single Surface Mount, Red with clear lens, Used, Qty 1, $45
#233 Star Warnings System, Model ULB9-RR, Red, Used, Qty 1, $10
#234 Dome Light 3” Round LED, Red with clear lens, Used, Qty 1, $10
$251 Whelen Single Avenger II Duo (overstock), AVW12D, Red/White, clear lens, Includes plastic visor
Qty 1, $161.42
#255 Whelen (overstock), Model RVR03ZCR, TIR3 Vertical Mount, Sync, ,Red, Qty: need to recheck , mount, $65 each
#256 Whelen (overstock), Model 0RR00FCR , Qty: need to recheck amount, $25 each
#257 Whelen (overstock), Model 60R00FRR, 600 LED Flasher Red, Red, Qty: need to recheck amount
$225 each
#320 Whelen Universal Hid-a-way lamp, 01-026A436-500, Red, Qty 4, NEW in packaging, $45 each or 4 for $150
#321 Whelen Strip Lite Smart LED Flasher, PSR00FRR, Red with red lens, Qty 1, $70
#322 Whelen M7, M7R, Red with red lens, With Chrome surface mount brackets, Qty 2, $110 each or 2 for 200 with brackets
#323 Whelen M7, M&RC, Red with clear lenses, No brackets, Qty 2, $100 each or 2 for $180
#324 Whelen M6, M6D, Red/White with clear lens, Qty 1, $120
#325 Whelen M6, M6R, Red with red lens, With chrome surface mount bracket, Qty 1, $110
#326 Whelen Single Avenger Dashlight, AVN1R, Red with clear lens, With windshield bracket, black
Qty 1, $75
#327 Whelen ION, IONR with windshield bracket, Red with clear lens, Qty 1, $55
#328 Whelen Vertex, VTX609R, Red with clear lens, Qty 4, $40 each or 2 for $70 or 4 for $130
#329 Whelen original Vertex, Qty 1, original “6 LED hideaway”, Red with clear lens, $20
#330 Feniex Cannon, Red/white with clear lens, Qty 1, $10
#331 Whelen V2 Light, V23RTPB, Red light clear lens, Qty 1, $135
#332 Whelen ION, IONR, Red with clear lens, Qty 4, $50 each or 4 for $175
#333 Whelen ION smoked, XI2D, Red/white with clear lens, Qty 1, $60
#334 Whelen LINZ6, LINZ6R/01-06B042450A, Red with clear lens, With black brackets, Qty 2, $20 each or 2 for $35
#335 Whelen, 01-026B0424R0C, Red with clear lens, With black bracket, ,Qty 1, $20
#336 Whelen TIR3, Red with clear lens, With black surface mount brackets, $15 each or 2 for $25
MISC.
Qty 2, 90FLANGC, Whelen 900 Super LED Chrome Flange. NEW. Our cost $16.74 each.
Qty 7, BBKT20, Whelen, “L” bracket L20/2500/2000 Ser. NEW. Our cost $28.62 each.
Qty 2, 9FLANGE, Whelen 9E/900 Chrome Plate Flange Kit, NEW. Our cost
Qty 7, DBKT3, Whelen Dominator D2/D4 swivel mount. NEW. Our cost $20.64 each.
Qty 1, DBKT4, Whelen Dominator angle mount bracket. NEW. Our cost $14.30
Qty 2, L6BKT5, Whelen under the sideview mirror mount. NEW. Our cost $11.60 each
Qty 2, PCC6W, Whelen PCC6W Switch Control Center. NEW. Our cost $65.00 each.
Qty 39, WCCP, Whelen WECAN Universal control point. NEW. Our cost $78.00 each.
Qty 2, 40303, Rigid Industries, 3 LED 921 RV Light Kit. NEW. Our cost $14.99 each.
Qty 1, 40337, Rigid Industries. NEW. Our cost $64.99 each.
Qty 1, JW Speaker 3156351, 8700 Mounting Ring Kit. NEW. Our cost $59.85
Qty 1, JW Speaker 8200001, Mounting Ring Kit par 46. NEW. Our cost $79.20.
Qty 1, Buell Air Horn, 1062, 12” Strombos air horn. NEW. Our cost $154.50
Qty 2, Fire Research, model 530 Telescopic Poles. NEW. Our cost $
Qty 5, AP-VESA-75, Hint adaptor plate for VESA 75mm hole pattern. NEW> Our cost $38.50 each.
Qty 3, 425-6293, Jotto Desk Faceplate. NEW. Our cost $19.18 each.
Qty 1, 234-3, FAM Mount Laptop Mount Tough Tray. NEW. Our cost $55.99
Qty 1, HSN4040A, Motorolla External Water Resistant Remote. NEW. Our cost $64.44
Qty 2, PT-A-902, Havis Flip Down Step Option. NEW. Our cost $395.58 each
Qty 2, PT-A-903, Havis Prisioner Transport Power Vent Option. NEW. Our Cost $347.80 each.
Qty 15, C-VS-0618-INUT, Havis 2020 Ford Interceptor Utility Specific Flat Console. NEW. Our cost $274.32 each.
#1 Whelen headlight flasher, UHR2150A, New in the bag, Qty 1, $45
#12 4” Round Light, stainless steel guard., Qty. 2, $15 each or 2 for $25
#17 Kenwood Remote Control Cable, for 7160 or 8160 Kenwood Radio , KCT-22 M3, NEW in boxes, Qty.3, $70 each or $180 for all 3
#18 Kenwood External Speaker, KES-5 M, NEW in box, Qty.1, $50
#21 Desk Top Base with Built-In Speaker, For XTL Series Radios, Model HLN6042A, Motorola, Used, Qty.1, $15
#29 Sho Me Four-Function Switch Box, With Backlighted Legends, 05.4004, NEW, Qty. 1, $80
#35 Strobe Power Supplies
Total quantity of 14 - all are used
qty 1
Tomar 780-1228 WP
65 watt
qty 4
Tomar 786-1228 WP
65 watt
qty 1
Tomar 780-1228 PR
65 watt
(770’s are fast, 780’s are slow)
$180 each
#42 Federal Signal Night Fighter Area Light, Model FL3SF-LC Series A, 3 bulb lamp 4007/7680, Qty. 1, $300
#111 Armrest/Consoles, Some of stitching is worn, Metal boxes with hinge, Used, Qty 2, $12 each
#114 Federal Signal Ricochet 6 Head Power Supply, Strobe Power System, Model 413106 Series A, 12/24 VDC, Qty 1, $70
#115 Haris Screen Stoffemers UT-X, HWK-SS-UT-X, NEW, Qty 5, $70.00 each or 2 for $130
#151 Tomar Brackets, RECT-14BKT-VX2, Qty 3, New, in plastic, $30
#230 Traffic Director 56 (LumiLEDs), SN: 7807566 Version CC1, Red with Amber on ends, Used, qty 1, $45
#237 Tomar, RECT 37LLW-A/R, ½ Amber, ½ Red, Used, Qty 1 $45
REAR VIEW CAMERA SAFETY ITEMS: (our costs)
<td>
1​
td><td>RVS-775td><td>Side Cameratd><td>
$80.00​
td><td>
1​
td><td>RVS-6137Ntd><td>7" Rear View Monitor (RCA Connectors)td><td>
$88.00​
td><td>
2​
td><td>RVS-770613-112td><td>Rear View Camera System with Sensorstd><td>
$279.75​
td><td>
1​
td><td>RVS-770613-NM-01td><td>7" Display, 1 x Backiup Camera, 66' Cable.td><td>
$229.67​
td><td>
1​
td><td>RVS-770616-NM-05td><td>9" Display, Backup Camera.td><td>
$476.00​
td>
SPEAKERS: ALL SPEAKERS LISTED ARE USED
#200 Motorola, Hand helds, HMN 1056D, Qty. 3, $12 each or all 3 for $30
#201 Motorola, HSN 4030A, With Bail Bracket, Qty. 1 , $10
#202 Motorola, HSN 4038 A, With Bail Brackets, Qty. 2, $15 each Or 2 for $25
#203 Motorola, HSN 4031 B, With bail brackets, Qty.5, $20 each Or 2 for $35
#204 Motorola, HSN 1000B, With bail bracket, Qty. 1, $12
#205 Motorola, HSN 4035A, With bail bracket
#206 Motorola, HSN 4032 A, With bail bracket, Qty.1, $12
#207 Motorola, HSN 4039A, With bail brackets, Qty. 2, $20 each Or 2 for $35
#208 Johnson, 250-0151, With bail brackets, Qty.4, $12 each Or 2 for $20
#209 GE Ericsson, 19A14959OP1, Qty. 2, $15 each Or both for $25
#210 Uniden, Model ESP26, With bail bracket, Qty.1, $10
ur20v
571
Northern Virginia
@Git Lit - I'm having trouble trying to message you, but I'd like to purchase this:
"#213 Code 3 Oscilater, Red lens, Used, Qty 1,,Qty 1 missing bulb, $15 each"
Would you please message me so I can provide my zip code and we can discuss payment details? Hopefully the messaging system works for you...
Tony P
Moderator
Sep 13, 2015
1,948
Midwest, USA
@ur20v You have too many messages in your inbox. Clear out some old ones and you should be set!
Tony P
Moderator
Sep 13, 2015
1,948
Midwest, USA
I tried that... it got tedious quickly, and I'm already beyond tired. Maybe I'll find more time to go through them all tomorrow or this weekend.
No one, including staff, will be able to PM you until you clear them out.
StEaLtH2
2,159
New England
Hello Git Lit. I don’t think what was posted just above was directed at you or your ad. The messaging system here is private message based. That is where things like an offer on an item or payment and shipping details can be exchanged.
I’ll send you one now. Welcome
Hmood
