Here's my 48" Whelen Liberty lightbar, model SX8, manufactured 09/07. I recently bought some of the new Super LED takedowns to replace the halogen ones that came with it. When I light up the bar everything works flawlessly .... except the new super takedowns. I tried powering them up both flashing and steady burn, with no success. Plug the Halogens back in and they work fine. The new Super Takedowns came with the same factory plugs which fit perfectly with the plugs coming from the wiring harness. You can't mess them up because of the notches and grooves on the plugs don't allow you to inadvertently connect the power to ground or vice versa. So whats going on? Is there a compatability issue because the bar is a couple of years old? I'm gonna call Whelen's tech line but if anyone can save me the time I'd appreciate the help in figuring this out.
Thanks in advance, Jason C
