Ok, I have looked and looked and I am unable to locate much information. This will all be for I assume a 2011 Tahoe. I am focusing on the back right now and looking for advice. I was thinking of using the stock flashers for the tail lights ( brake and back up lights) or installing LED flashers. I have seen both, Universal LED and the Vertex talked about but I can not seem to find information on which is better. The Universal is much more money and needs a control head, and is different in design. For the back lighting, should I stick with stock, or LED and if so, which would be better?
On a different note, I am hoping to install LED's in the fog lights, how does this sound? Again, which would you suggest between the two or put in a solid state flasher like wig-wag?
Thanks for any thoughts.
