RBRONKEMA GHTFD
Okay guys I have a question, which has been stumping me. I installed a MX7k on a guys truck over the weekend. I custom made a switch box for him and put 7 rocker switches in it. I started at the battery with a 30 amp fuse. Then ran a 10 ga wire to a fuse block inside the switch panel. then I put 2 30 amp fuses on the block and ran a 12 ga to power the switchs and relays. The first 4 switchs have relays. I fugured I'd put relays on the first 4 being they are going to be on the most running the lower flashers, sweeps, and 5 rotators. Also the 4th switch is for the take downs. (they do not flash I just thought I'd put a relay on it because those get used more than alley lights and rear work lights.) Now my question is why does the fuse at the battery keep blowing? It only blows if he has more than 4 switchs on at once. I had this bar hooked up the same way on a different truck and had no issues before. Should I add a relay to the main power wire or what? Thats what I am thinking about doing but I am not sure what I should use to "trigger" the power. (trucks a 02 dodge ram.) I don't want to add a bigger fuse at the battery as I am afraid it may cause a fire. Also everything including the bar is grounded at the battery. Everything is ran thru groments and in loom also so it wont chaffe on anything. Any thoughts. Thanks in advanced. Like I said this has been bugging me and has been hooked up on a different truck before the same way and the guy never had a issue.
