John Hearne
I need to wire STT lights into a number of current Dodge pickups that will be receiving full-size lightbars. What is the best way to pickup the appropriate connections?
John Hearne said:I need to wire STT lights into a number of current Dodge pickups that will be receiving full-size lightbars. What is the best way to pickup the appropriate connections?
emergency_ram12 said:Just be careful and not short out the wires when tapping into the wires. The trucks heads and tails run an integrated TIPM and the fuse isnt located in the fuse box so it will require it to be taken back to the dealership if it is blown.
Shawn L said:why not intercept the trailer harness at the back of the cab? the wires are going to run to the rear at the plug, I agree if you have a dedicated trailer harness why not use that.
+1 on this. Great item.kitn1mcc said:if these trucks are not gonna have the stock beds/tow hitch the wires will be blunt cut at the rear. get a splice box like this 7-Breaker Junction Box 10-32 Threaded Studs
mount it under the rear of the truck. that away you can wire up the STT and also still have the trailer wiring avail i use those alot they work great
