Wiring turn signals to liberty light heads
Da-Sarge
393
Canada
I'm not sure if this is the rite spot or not but here's a question for you Lightner modders out there has anyone attempted to wire light heads in their amber liberty light bar to their turn signals? I know there is stop tail turn modules available but not sure if they are for the liberty. anything you guys might know or know of by all means. is there a 3 marker light insert for the front and rear that would fit maybe under the light heads or on top. I figured I would check if there's anything that's a possibility.
shues
NW Indiana
The Towman's Liberty includes a pair of 500-series stop/tail/turn lights on a separate, four-wire harness. The harness needs to be wired in to the tail light circuit, the left turn signal/brake light circuit, the right turn signal/brake light circuit, and ground.
FusionWolf
504
Massachusetts
You could pretty easily retrofit marker lights into the bar. As far as integrating your amber modules into the turn signals: the short answer is not really without doing some extensive modification. However if you have a wecan bar or want to do a wecan bar IO swap then you could pretty easily program in turn signals by just programming them to one of the outputs on your interface module or into a cencom, carbide or cantrol unit input wire.
jriccio@necommunications.
