BFE127
How to read a model number??? HO9UCF9PW7BN is the number? What will this radio do? I believe it is an 800 mhz. HELP?
hawkspringsfire said:U=806-870 MHz. If you can get the flash code we will be able to tell you what the radio has been flashed for as well.
BFE127 said:I bet you would buy it for $25!!!! lol I'll get the boys to check it out for me, then list it for a reasonable price with all the extras. Thanks
SlickTop Solutions said:Just thought I would offer...
As mentioned above, press the button just above the PTT 5 times after start-up is finished, it will provide you with the Host, DSP, Encryption (if any), flash code and serial number.
The flash code can be decoded here: akardam.net Motorola Flashcode Decoder R04.03.01
If you need help with it, give me a holler and I will be happy to help.
fleetcomm said:The problems with the xts3000 was it had to be retuned alot and they are no longer supported by Motorola.
SlickTop Solutions said:I've never seen that or know of nay major municipality that had a major issue with the 3000. Do you have info you can point to for reference please? (would like to have it in the save file)
