Axixtech ST6 (Super Thin) Surface mount
pdk9
3,834
New York & Florida
That looks like a great, universal option for under rear liftgates without having to recess mount (and for low-pro surface mounting as makeshift mirrorbeams)
Carlos SpicyWeiner
May 3, 2012
5,233
Lakeland, Florida
Are these required to be mounted to metal surfaces for heat dissipation?
PJD642
1,543
east of Cleveland
Wow. As said above, those would be PERFECT for tailgate mounting, and would have saved me a bunch of time with the dremel notching the grille on my Explorer.
Any chance of a "spot" configuration, or would that require thicker lenses & defeat the purpose?
okc_f150
318
Oklahoma City
Can't wait to see a video of this baby in action!
May 24, 2010
1,627
PG County, MD
PJ,
I believe they will have the same optics as the MS^ series (TIR internal optics with a defuser cover optics). I will post pics and video once I get our demo units.
RecElect
331
Loveland, Colorado
We just got a few of these in to sample.
They are the Axixtech St6. We only got the them in amber but axixtech says all colors can ship.
I am damn impressed by these things. They are under .5" thick, and have a massive output. We think they would be perfect for use as side fender lights, or under doors. They actually look pretty good on the front of a push bumper too. You could bolt them right to the crossover without having to have another bracket and they would not protrude to the point that they would get damaged if the push bar were to be used.
We have put it up against some similar lights like the sound off ghost, Feniex cobra t6, and the MS6 series from Axixtech and it is just as bright, but way lower profile.
We have ran it on our test bench for 24 hours, and the whole light is warm as you would expect. I actually expected not to be able to touch it due to its size, but it seems to dissipate heat very well.
The light has an aluminum heatsink and a lens that is adheard to that. I also like the cable that leaves it. it has 18 gauge wire and is way easier to work with.
For it's size, it feels pretty durable, and really, there is not much to break on it. Super simple light, thin, and bright. built in flasher and sync able.
MSRP is around $100 we would be selling them for $75 each.
What do you think?
ai1096.photobucket.com_albums_g333_wiredhdh_Axixtech_20140104_0827440_zpse5b53ce1.jpg
ai1096.photobucket.com_albums_g333_wiredhdh_Axixtech_th_20140104_082629_zps707cd3c3.jpg
paff2
842
Lancaster, PA
bluestinger90 said:
Thanks for the review. Have you had a chance to test it with external flashers? Axixtech ms3/ms6 are not compatible with external flashers.
That would be my question as well.
paff2
842
Lancaster, PA
WIRED HDH said:
I will hook them up to one on monday and see if they will. I am guessing no if the m6 series doesn't...
Did you have a chance to check them?
paff2
842
Lancaster, PA
Days and months have gone by and no answer to the question. Can these be hooked to an external flasher?????
Columbus, Ohio
I hooked a pair up to a simple wig wag flasher and ran it for five minutes with no issues. I know I have a more advanced flasher with more patterns somewhere but darned if I could find it last night. Hope that's at least some what helpful.
minig0d
689
LA & TX
Hmmmm these would definitely be nice looking to make some fake "Mirrorbeams" out of.... Wouldn't stick out like most lights would or need a cutout like recessed would....
Eric1249
2,277
Waukesha WI USA
I got a pair of these. They have a different name on the box. I set them to steady burn and they would not work with a flasher. Could I be doing something wrong? Here is a couple pics of them mounted.
paff2
842
Lancaster, PA
I hope its just something set up wrong. I know in another post someone had tested it with an external flasher and it worked. I was was planning to order a pair but may have to reconsider.
Carlos SpicyWeiner
May 3, 2012
5,233
Lakeland, Florida
Which flasher are you using? Make sure you are not using a negative switched flasher......
rwo978
ND, USA
Not all LED heads are compatible with LED flashers. Some heads have a microsecond delay before power on, which makes them 'play poorly' with external flashers. Example, was trying to sync 2 FedSig LED Highlighters off an external flasher, which also happened to be a FedSig flasher. The HL had a very small delay before power on which made it impossible to use them with the external flasher.
I suspect that is the case her as well.
Carlos SpicyWeiner
May 3, 2012
5,233
Lakeland, Florida
Apparently it doesnt matter. Sorry. I guess these lightheads have too much of a delay
woobatu
