Burnt out Slimlighter LEDs
NJEMS1
38
NNJ
I hope this is the correct place.
Recently picked up a new to us chiefs vehicle that had a slimlighter installed in the rear glass.
We plan on replacing it because 2 of the 6 leds on one side do not work. Has anyone come across this before? Is there a way to replace just the LEDs or does whelen make replacement modules?
would love to get them all working again.
shues
NW Indiana
I have seen this problem occur in at least one instance where the four-pin connector that connects the LED card to the driver board was not making a good connection. It's strange, but I have seen it happen. I had to solder the socket back onto the LED card in order to get all six diodes to light.
Apr 13, 2012
24
Texas, USA
I have several Slimlighters and one of them had the same problem. I took off the clear lenses, and saw that the solder connecting the LEDs to the circuit board had broken. I used my soldering iron to put some drops of solder on the existing solder. It worked. I put the clear lense covers on the Slimlighter and put it back to work. It sill works.
StormChase85
