Here are some pics of the 1954-1955 ROTA-BEAM RB10 after clean up.
I just need to add the proper wire and cig. plug.
I wanted to rechrome the base, but the spindle that accepts the lens cage is pressed on to the motor shaft. The only way to remove the motor is to remove this spindle, and there is too much chance of damaging the motor assy. if I try that. This is the way it will stay. Not bad for a 60 year old light, and it works as it should!
Note: Later versions had a larger hole in the base to allow the spindle to slide through, allowing easy motor replacement.
The base is chrome plated steel. Later they went to chrome plated brass, and then stainless steel.
The dome is attached with 2 acorn nuts at the top, and uses a very thin gasket at the bottom of the dome, as opposed to the heavy rubber dome gaskets used in later 2nd and 3rd generation ROTA-BEAMS.
3rd generation lights have a somewhat different design of lens cage, with metal tabs bent out, to help stop the magnifying lenses from vibrating out of the cage.
Note RB10 and JOLIET, ILL location of Whelen Engeneering on the tag!!
The tag is chrome plated brass, as opposed to the later aluminum tags, and the mounting holes place the tag lower on the base, some what interfering with, or being coverered by the base gasket . The tag is also smaller in height than the later versions.
This light is tagged as a 6 Volt model. There comes with the light a paper describing how to change the light from 6 to 12 Volt by cutting a resistor under the base, in line with the motor, and replacing the 6 volt bulb with a 1196 12 Volt bulb. Voila! It is then a 12 Volt light!
I wonder what this light was used on. Hearse/ambulance combination, fire chief's car, police vehicle?
This was Whelen's very first automotive warning light. (1954/1955 vintage)
Whelen's first automotive light was portable / magnetic mount.
It's interesting to see all of the engeneering revisions made in 1st and 2nd generation lights to come up with their long lived 3rd generation ROTA-BEAM.
More history is on page 1 of this thread.
