2005 Jeep Grand Cherokee
lytsnsrns
280
Milwaukee, WI
Hello all,
So I recently decided to actually bite down and finish my vehicle. Below is the current equipment installed. My original plan was to use a Apollo 600 behind the grill, but the siren speakers wouldn't allow that, my current problem I would like to solve is to get more lighting to the sides, but I will not drill into the bumper or fenders. I am thinking of doing either a Feniex rocker panel kit or few smaller light heads on the rocker panel. I will attempt to post a video of what I currently have except there is no white due to park kill.
Vehicle is a 2005 Jeep Grand Cherokee Limited
Currently have the following done to the vehicle:
Rear
  • Tomar RECT13 L-Stick 8 Head Red - Window
  • Feniex Cobra T-6 Red - License Plate
  • Feniex Cannon 120 Red/White - Reverse Lights (Wired to flash red, override for reverse and scene light.) I am slacking on changing the pattern on them from the red/white to just red.
Side
  • Sound Off nForce Red/White - Window
Front
  • Sound Off nForce Red/White - Window (Steady burn White for Takedown.)
  • Tomar RECT-14 Red X4 - Grill (Custom made brackets)
  • Feniex Cannon 360 Red/White - Fog Lights (White fog lights, Red warning take over.)
  • Sound Off ISO Select-A-Pattern Headlight Flasher
All controlled by a Sound Off nErgy 400 dual tone remote siren, with 2 Sound Off 100H Speakers.
Slide 1 (Rear/Minimal Sides):
  • Rear Cannons Flash Red
  • Rear License Plates Lights
  • Rear Lightbar
Slide 2 (Includes Mode 1)
  • Rear Side Window nForce (Red only)
  • Front Window nForce (Red only)
  • Front Cannon Fog Lights
  • Tomar RECT 14 in grill
Slide 3 (Includes all of Slide 1&2)
  • Activate HLF - Powerpulse Pattern
  • Activate dual color on all nForces
bmd224
324
NE Kansas
Roof racks make great mounts for lights--especially side lighting. A Feniex T3 or T6 may fit in the gap between the BOTTOM of the roof rack's side rail & the roof. Mount it to the bottom of the roof rack so its hanging or suspended from the bottom of the roof rack.
Bogie
126
Queens,NY
While there is a air gap on the roof rack I don't believe any light head would fit. Might be able to surface mount something narrow like a SOS Ghost if you made a proper angled base to level the units
exploder97
