2005 Pontiac Grand Prix Front Strobes
dsanchez
Festus, MO
I have a 2005 Pontiac Grand Prix GT and I would like to put some strobes to the front. I have already done the rear. Problem is, with clear headlight lenses, I do not really want to put a strobe tube there. Has any one ever put strobe tubes in the lower fog/turn signal light housing on a Grand Prix? Appreciate your guidance and knowledge.
Thanks.
Dennis
cory y
Well if it was me, id put the haw in the turn signal portion of the assembly. The light emitted from that housing will not overpower the tubes like a fog light or headlight has the ability to.
Fast LT1
2,017
Sedgwick County, KS
I'd pull out the fog light bulb if possible and put he strobe in the oem hole.
RDT Car 25
360
Milford, CT
Just keep in mind that the housing should be at least as big as an adult fist. This will make sure that the heat build-up will not damage the housing. Also, make sure the strobe tube is not too close to the front lense. Looking at a few pics from a Google search, it looks like they should be ok.
ddd
