2010 Nissan Xtrail *Modified Whelen HFSA1, pic update page 2
1911
66
Indonesia Java
Nissan Xtrail 2010. Indonesian Federal Police (Markas Besar Polisi Republik Indonesia)
All of the equipments are from the previous car (Grand Vitara, feat on the old site)
Whelen 295HFSA1 Siren
Whelen SA315SP Speaker
2 Whelen B/B Slimlighters up front
4 Whelen B/B TIR3 at the back
Whelen Wigwag. Forgot which series, installed on the factory halogen light on the roof rack since the highbeam on my car is HID.
Whelen HAW strobes. Not yet installed.
Whelen ULF44
Federal Signal Rumbler
Antenex Antenna
Motorola ATS2500
Front
[Broken External Image]:http://img40.imageshack.us/img40/6171/img01413201006081514.jpg
Rear
[Broken External Image]:http://img193.imageshack.us/img193/7769/img01414201006081515.jpg
Custom Made Switches, include the pattern selection buttons.
[Broken External Image]:http://img52.imageshack.us/img52/1913/img01404201006081511.jpg
[Broken External Image]:http://img29.imageshack.us/img29/8150/img01405201006081511.jpg
Custom Rear molding for the TIR3s
[Broken External Image]:http://img37.imageshack.us/img37/3870/img01393201006071325.jpg
Antenex
[Broken External Image]:http://img443.imageshack.us/img443/2263/img01406201006081511.jpg
Slimlighter
[Broken External Image]:http://img43.imageshack.us/img43/5455/img01402201006081510.jpg
SA315SP
[Broken External Image]:http://img18.imageshack.us/img18/7288/img01409201006081513.jpg
Rumbler. A very tight fit
[Broken External Image]:http://img689.imageshack.us/img689/870/img01412201006081514.jpg
So far the car hasnt finished its installation yet, there are some little bits and pieces still needed to be done. I'll update once its all done.
I have seen a guy make his HID high beams on a 2010 Escalade wig wag they are crazy bright. I was told they can burn out.
I like the roof rack lights, I don't think I've ever seen them from the factory like that.
Ya that is super dangerous and just asking for a huge repair bill those are not cheap to replace, especially the ballast.
+1 -the ballast is NOT made to :"do" a constant on/off
He has it for quite some time now and it hasnt had any problems yet. The wig wags are very bright and move traffic . The Escalade is the only HID wig wag I have seen so far. I guess if he can afford a new Escalade every 2 years and pay for a nice install he can afford to put in new HID's if they burn out. He just ordered 3 Tomar High power 200s to put on his roof rack to maintain the slick top apearence. Ill try to post some pics when the lights are added.
Thank you guys for all the compliments, really appreciate it. The slimlighter's mount actually looked lower than it actually is, its not that bad.
The roofrack light really helped as the substitute for where the wigwag's gonna be, it really worked out much better than if it would be on a headlight. The high position really grabs people attention.
Hows that phantom working on a mag mount antenna base. I've always used a hole mount to the roof, so its base makes contact with the roof of the vehicle. Looks a little hookey, but if it works and the owner is happy....ok.
The installer wanted to drill holes into the roof, but i requested not to to prevent any leaks etc. So what he did was simply use the magnetic bracket, and added 3M double sided tape. Ran the wire into the gab between the rear light housing and the body, and run the wire using the factory cable hose.
the install is clean, and the car looks good,
my only beef with this install is that the roof lights are washing out the visor lights. I would add some lighting in the grill, or suction a dash light at the bottom center of the windshield.
The rear looks good, a little LAW never killed anyone ;)
looks even better in the video,but you need some lower and or mid level warning
VolEms said:
Nice vid . I would put 2 grille lights .
Yeah i was thinking of the same thing, but our local law doesnt require 360 degree warning coverage. Plus the car wont be responding to any emergencies, its used mainly for escorting government convoys, there will be marked units clearing traffic infront anyways. Incase of low profile incognito, the warnings are more than sufficient.
Thank you for the gracious comments, kudos to the installer, i just provide them with the gadgets :D
I am extremely interested in the slimlighters in the windshield. I see they are mounted with suction cups but how is the flashback shield mounted and what is it fabricated from? I would love to do something similar with my setup. Could you give any more info? Thanks...
The shield is black acrylic, cut to fit, and the edges that touches the windshield are fitted with a rubber list. I dont know what its called, its easily found in most hardware store i guess. The acrylic is mounted with a 3M double sided tape. We later added the metal mounting bracket to support the slimlighter after the suction cup keep failing in hot weather.
Nice ride.
I agree about the lack of mid-level lightning. Even if your laws don't require 360 viz, a couple grille Xtreme 4 in blue/white would work wonders... ;)
TheGatekeeper said:
Nice ride.
Yup i'll definitely look into the 360 coverage. Thank you :)
That siren control looks incredible! How long did it take you from start to finish?
Looks good. Might wanna add something to the sides though. And I do like the wig-wag with the roof lights, those aren't something you see on any American cars...
These have LED headlights, flashing those is perfectly fine.
Thank you sir. Whole thing took around 3-4 hours, including installs (just the siren). I wasnt the one doing the install, and unfortunately have no knowledge of any of the technical details :)
kb1sph
