2017 F150 Cencom Core install. Where to mount?
ryan81986
528
12
Boston, MA
So I'll be doing a core based install soon in a 17 F150. The only thing I'm stuck on at the moment is where to mount the core and associated wiring. I'm thinking behind the rear seat but I haven't opened it up yet.
Anyone have any insight on locations?
I'm not currently planning on putting a Havis console in, so mounting everything in the console is not currently an option.
I was thinking under the seat as well but was debating keeping that open so that the rear seats could be folded up for storage use. But keeping that idea open as well.
From my experience most pickups have very minimal options for installations. Some may have space behind the second seats on the back wall but under the second seats is consistently the most straight forward when doing an entire upfit.
If ur worried about cargo space a cover for the bed maybe a better option.
Behind the back seat on the rear wall is our go to. The latch is a bit tricky to unlock. It's out of the way and you can still fold the seats up of you need to load the inside down.
Do you happen to have any photos/tips on attaching a mounting plate to the rear wall?
We are working with Troy to have this plate mass produced. It was scrap from something laying around the shop, allows fewer penetrations in the rear wall and fit perfectly.
We've done several with the equipment mounted directly to the body. When doing this put a dab of silicone on the metal before using a self drilling screw to prevent water intrusion.
Try under your back seat the bottom lift up. I had a 2017 F150 and I had my radio box , siren box and a fuse panel mount there
I did the same on the back wall of my 16 2500. I wanted the space under the back seats free as I fold them up for the dogs and put a full size dog bed in there for road trips or adventures. I had to cut away some of the thick sound shield insulation Chevy puts in. Believe it or not flex glue as seen on tv worked awesome to glue a cut down awards plaque that Lowe’s sells to mount my smart siren to. I trimmed pieces off another to hold my terminals and one smaller one to mount my rumbler.
Of course if you have to perform any work or modifications later you’ll have to pull the seats every time, but it’s worth it to save the space. I kept the smart siren as low as I could to at least be able to see and troubleshoot with the fuse leds on it, and a few of my main fuses for the power wire for my Cn signalmaster and ils are at the bottom in the event they ever need to be looked at without pulling the seats. But if I ever need to get to my terminal blocks it’s an hour And spare set of hands to pull the back seats.
Worth it to not lose the space though.
Reactions: EngrDiver
Do you have pictures? I'm thinking of doing this to my 2014 Silverado 1500 and would like some tips.
I can grab a few with my seats still in place. It’s been about 2 years since I put it in. I was considering going back in this fall and cleaning up a lot of the wiring especially since I’ve moved to my two main bars being data cable operated there’s a lot of area I can clean up from when I had my other bar which was 12v switching.
Reactions: Mattdecker
Gotcha. Thanks.
My 1500 is a double cab so under seat space is pretty limited.
Mluna53
