2017 F250 Whelen Warning lights using SmartLogic Flasher
fordtruck661
96
11
CT
Hi All,
Just fished the warning lights on my 2017 F250. I used a variety of Whelen Duo and Trio IONs around the outside of the truck and two Star Mini Phantom lights on the inner windshield. All of the lights are controlled by a Whelen SmartLogic flasher. The flasher is programed to automatedly put lights into low power mode using a Whelen Photocell and will automatically put lights into park mode using an output from the trucks transmission. Overall I am happy with the way the setup came out and very happy with the endless ways I can program and control the SmartLogic flasher!
Attached is a video for your viewing pressure.
Sharp!
Looks very nicely laid out. Patterns are great.
I think if I were to ever redo my lights I would use the smart logic flasher. Looks to be very user friendly, and customizable.
And the lights flickering is ???
If your asking what the flash pattern is its called steady flash. The camera does not do a good job of picking it up but they do a quick flicker every few seconds.
Sharp!
Thanks I put a lot of thought into the patterns. It is a great flasher and I think it doesn't get the attention it should.
Reactions: firebuff17
ste01a
