Wanted 24S aerodynic frame
turboboost
124
France, PAris
Hello I'm restoring a 24SEAH aerodynic lightbar and the frame I have is highly damaged. I need another one. So if any of you is parting out a 24S lightbar drop me a line.
I also need gutter mounts parts:
- The 2 nuts at each end of the curved gutter bar (see first pic). You can see a smaller nut that goes into the biggest one. I need both, 4 of each,
- The plate with welded threaded rod (on the second pic it's the part on the right) that slide into the bottom of aerodynic frame. On this plate I'm looking for, you screw the mounting clamps (parts on the left of the same pic) and then the curved gutter bar.
turboboost
124
France, PAris
I have to correct my first post. Regarding the nuts I need, I just need the nuts with the holes in their center. I have enough of the smaller ones, and Iforgot to mention that I also need 2 of the triangle shaped parts.
turboboost
124
France, PAris
Update: following a pending deal, I now need:
- 1 of the triangle part,
- 2 of the biggest nuts (the ones with the hole in their center),
- at least one but 3 would be better of the plate with the 2 threaded rods
I'm seeing for a 24S frame with Mars Light.
turboboost
124
France, PAris
Hi, still looking for the following parts for the gutter mounts:
turboboost
124
France, PAris
Pending deal on the plate/rod assemblies.
I'm still looking for the following parts for the gutter mounts:
- 2 of the biggest nuts (the ones with the hole in their center.
Thanks
woobatu
