4200DL and stormpro100 question
needforspeed
145
Massachusetts
I'm sure this is a JV question but, I have a 4200DL controller and want to add a stormpro 100, is this accomplished with the RJ45 Jack and programming of the controller or do I need to program the tones on the 100 and then hook each input to an output on the relay panel?
Any input is appreciated (pardon the pun).
Carlos SpicyWeiner
May 3, 2012
5,233
Lakeland, Florida
You can use the RJ45 jack and programming. Set tones for the modes the old school way makes it easier.
needforspeed
145
Massachusetts
Install took all of about 10 mins when replacing whelen amp. Hooked up the positive and negative wires. Then the speaker wires and RJ-45 cable. Reprogrammed the controller to use the StormPro siren and everything was done.
The sound is crisp and just as loud as the whelen amp that came out.
Reactions: Tony P
Caldwell205
