Adding a Module to Mini-Liberty
Boss429
Pennsylvania
I have bought a New LIN6 500 series module from HPD84. It should come sometime this week and I was just wondering how to hook it up. The bar has a ULF44 flasher in it but there is no open spot for it on the flasher. Where/how do I hook it up?
Picture:
Got the module today...nobody knows how to add it to my liberty?
I'm not an expert in min-liberty's but I do have the same flasher.
The flasher has 4 ports and as you state, all ports are taken. You'll probably need to "tap" in to one of the channels with the new module. I assume you'll be putting this new module in the center section (since it is the only spot). By tapping in, the center section is going to flash at the same time as one of the ends.
You could re-wire things and make the 2 ends alternate with the new module in the center.
Hope this helps.
EDIT: As another member stated, if it has its own flasher, you could just tap in to the power going in to the flasher. The light head will not be synced with the originals but, another option.
-Rob
Rofocowboy84 said:
Does it have it's own flash patterns? If so, just set it to one of those....
No, it is a module meant for a lightbar (2 wire).
Thanks guys.
hook the lighthead up to a steady 12 volt source fused at 1 amp. your bar now has a steady burn front light with the sides alternating. bitchen setup
kb1sph
